HP Color LaserJet 3600n
BROKEN
Status Broken - electronics error, feel free to fix
Training Optional
Hackable YES
If it Breaks (Panic procedure, usually involving emailing list and “broken” sign)
Loan Status Unknown
Arrival Date Date
Location 3D Printing area
This printer is broken and hackable if you wish
  • Hostname: vhs-printer01.vanhack.ca
  • IP address: 172.16.0.8
  • Drivers: link
  • Specs: link
Setup: Mac OS X
  1. Go to System Preferences → Printers
  2. Click the + sign to add a printer
  3. Select IP
  4. Enter the Address: 172.16.0.8 and select the Protocal 'HP Jetdirect - Socket'
  5. Use should populate with 'HP Color LaserJet 3600'
  6. Click 'Add'
Setup: Linux (KDE)
  1. Control Center → Printers
  2. Select 'Add'
  3. Select 'Network Printer'
  4. Select 'Other'
  5. Name Anything you want we suggest 'VHS_Lasjer_3600n'
  6. Make sure 'AppSockets/HP JetDirect'; is selected
  7. YOU MUST MAKE SURE Driver is set to 'Foomatic + hpijs'
  8. For path enter
    socket://172.16.0.8
  9. On the Printer Model Screen
  10. On the next screen make sure it knows the model is a 'LaserJet 3600'
  11. Leave the select defaults alone
  12. We recommend printing a test page
  13. Make sure to select 'Finish'
wiki/tools/hp_laserjet_3600n.txt · Last modified: 2019/04/23 14:17
