Boge Air Compressor
Big Ol' 7.5HP Air compressor! Arrived 2024-01-11 (partially killed in 2024-12-12)
Parts ordered from Pika Pumps in North Vancouver.
OIL CHANGE SHOULD BE DONE BY DEC 2025. Suction filter cleaned monthly. Section 5.3 of manual page 44.*
Make & Model Boge CL 7.5
Year of Construction 2012 (acquired by VHS from UBC in 2023)
Serial Number 5954443
CFM 30
Maximum Service Pressure 115 PSIG
Motor Speed 3600 RPM
Motor Power 7.5 HP (5.5kW)
User Manual (compressor) Boge Air Compressor Manual
User Manual (controller) Boge Focus compressor control manual
Status Operational as of Nov 2024
Training RTFM
Hackable NO (Please get consensus from all members before modifying, because this compressor provides compressed air for many different areas within the space!)
If it Breaks (Panic procedure, usually involving emailing list and “broken” sign)
Loan Status (Unknown, Owned, Permanent, Temporary, Semi-Permanent
Arrival Date Date (Donated by UBC)
Location Compressor head is in the compressor closet, receiver (tank) is under the laser cutter bench.
Champion none yet. @androidLX, @JohnC, or @fish are probably the most knowledgeable so far
This should outline safety concerns and guidelines for the tool and its operation.
Any maintenance, repairs, relocations, changes, etc. to the tool should be logged below with a note, date and who!
type Note Date Who
maintenance The oil thermal valve purred its last, so it was replaced along with a full oil change: oil filter, oil-air separator, air filter, scavenge line filter/cap replaced, and 2 gallons of S9000 Boge oil to keep the compressor purring smoothly. 2024-12-12 kittycat
repair A capacitor decided to nap permanently and was replaced. The motor coupler was also reseated to keep everything in pawsitive alignment. 2024-12-12 kittycat
maintenance 5 micron filter replaced 2024-11-12 JohnC
repair 0.3 micron filter unit bowl replaced (bowl was cracked) 2024-11-12 JohnC
Wiki entry created 2024-07-01 JohnC
wiki/tools/boge_air_compressor.txt · Last modified: 2025/01/12 18:00
