Delta Bench Bandsaw
Status Unknown as of November 2013
Training Recommended
Owner (VHS or Name of proper owner)
If it Breaks Unplug machine, put a “broken” sign on machine, contact Chris Cudahy.
Loan Status (Unknown, Owned, Permanent, Temporary, Semi-Permanent
Arrival Date April 2013
Location Danger Zone
Value $100
  • Safety Glasses
  • an experienced bandsaw operator (if this is not you, you must get someone to help you!)
  • Hearing Protection
  • Dust protection
  • Loose clothing
  • Loose hair
Safe Operation Details
Description: Before using set blade tension with the spring loaded lever on top of the machine and adjust the blade guides as needed. Release the tension when you're done. This extends the blade life.
http://www.wikihow.com/Use-a-Bench-Top-Bandsaw
http://servicenet.deltamachinery.com/Products/Detail/28-185
http://www.mikestools.com/ownersmanuals/28-185.pdf
wiki/tools/bench_bandsaw.txt · Last modified: 2025/01/06 19:51
