wiki:tool [2026/02/05 23:12] – Moved loaner note ziggywiki:tool [Unknown date] (current) – removed - external edit (Unknown date) 127.0.0.1
-====== Equipment and Tools at VHS ======
-<alert danger>
-**Many tools here can be dangerous.**\\
-If you are not qualified to use them or are unsure, please ask!\\
-A list of rules will not keep you safe; safety comes from knowing how to recognize all possible hazards and understanding how to deal with them.\\
-You are responsible for your own safety and the safety of others.
-</alert>
-All dangerous tools are **members only**. Non-members are welcome to use our soldering irons, hand tools, and test gear.
-When you add tools, please put follow [[wiki:tool:template-page|this template]]!
-===== 3D Printing =====
-See: [[wiki:area:3d-printing|3D Printing Work Area]]
-==== Machines ====
-  * [[wiki:tool:voron_v2.4_voltron|Voron v2.4 350mm: Voltron]]
-  * [[wiki:tool:jube_jubes |Jube Jubes Prusa MK3S]]
-  * [[wiki:tool:brian |Brian Prusa MK3S]]
-  * [[wiki:tool:sovol-sv08 |Sovol SV08]]
-  * [[wiki:tool:Form1SLA|Form 1]]
-  * [[wiki:tool:Vaquform DT2|Vaquform DT2 Vaccuformer]]
-  * [[wiki:tool:DittoPro|Tinkerine Ditto Pro]]⁺
-  * [[wiki:tool:3d-printers:AnyCubic Photon Mono | Photon Mono]]
-  * [[wiki:tool:3d-printers:AnyCubic Photon Mono X | Photon Mono X]]
-  * [[wiki:tool:3d-printers:AnyCubic Photon M3 Max | Photon M3 Max]]
-==== Supplies ====
-  * [[wiki:tool:3d_filament|3D Printing Filaments]]
-  * [[wiki:tool:3d_printing_resin|3D Printing Resin]]
-  * [[wiki:tool:glue|Glues]]
-//⁺ indicates available for loan//
-===== Sewing =====
-See: [[wiki:area:crafting|Arts and Crafts Area]]
-==== Machines ====
-  * [[wiki:tool:Sewing Machines]]
-  * [[wiki:tool:sewing_machines#VHS_sergers|Overlock Sergers]]
-  * [[wiki:tool:ironing|Irons & Ironing Boards]]
-  * [[wiki:tool:ironing#Conair_Steamer|Conair Steamer]]
-  * [[wiki:tool:relsew4000sw|Industrial Walking Foot]]
-==== Tools ====
-  * [[wiki:tool:Cutting Table]]
-  * [[wiki:tool:Silkscreening]]
-  * [[wiki:tool:ironing#Dress_Form|Dress Form]]
-  * [[wiki:tool:overhead_projector|Overhead Projector]]
-==== Supplies ====
-  * [[wiki:tool:pattern_paper|Pattern Paper Roll]]
-  * Donated Fabric
-  * Thermoplastic / Worbla
-  * Notions
-  * Pattern Weights
-  * Thread Rack
-  * Peg Board
-===== Art =====
-==== Machines ====
-  * [[wiki:tool:vinyl_cutter|Vinyl Cutter]]
-  * [[wiki:tool:Badge a Minit Button Maker|Button Maker]]
-  * [[wiki:tool:HP LaserJet Pro 400]]
-==== Tools ====
-  * Sculpting Tools
-  * Wood Burning Kit
-  * Paint and Sponge Brushes
-  * Exacto Knife Kit
-==== Supplies ====
-  * Origami Paper
-  * Jewelry Supplies and Beads
-  * Paint (Watercolour, Acrylic)
-  * Ribbons and String
-  * Stamps
-  * Stamp Ink
-  * Markers
-  * Sidewalk Chalk
-  * Balsa Wood
-  * Pom-Poms
-  * Pencil Crayons / Pastels
-  * Leather Scraps
-===== CNC Area =====
-See: [[wiki:area:metal_shop|Machine Shop]]
-==== Machines ====
-  * [[wiki:tool:Drill Press]]
-  * [[wiki:tool:Grizzly X3 4-Axis CNC Mill|CNC Mill "Gage"]]
-  * [[wiki:tool:jaxen_cnc_mill|CNC Mill "Jaxen"]]
-  * [[wiki:tool:6040 CNC Mill|6040 CNC Mill "Loratron"]]
-==== Tools ====
-  * Hand Tools
-  * Shopvac (shared with Machine Shop)
-  * CNC Tool Library (WIP)
-==== Supplies ====
-  * Safety Equipment
-  * Flux
-  * [[wiki:tool:fasteners|Nuts, Bolts, Screws, Washers]]
-===== Electronics =====
-See: [[wiki:area:electronics|Electronics Area]]
-==== Machines ====
-  * [[wiki:tool:Digital Multimeters (DMMs)]]
-  * [[wiki:tool:Oscilloscopes]]
-  * [[wiki:tool:Inspection Microscope]]
-  * [[wiki:tool:Essemtec PCB Oven]]
-  * [[wiki:tool:SMD Reflow Oven]]
-  * [[wiki:tool:Essemtec Pick and Place]]
-  * [[wiki:tool:Essemtec Stencil Screen Printer]]
-==== Tools ====
-  * [[wiki:tool:Hot Air Station]]
-  * [[wiki:tool:Soldering Stations]]
-  * [[wiki:tool:Third Hands]]
-  * [[wiki:tool:Panavise Junior]]
-  * [[wiki:tool:Infrared IC Heater]]
-  * [[wiki:tool:Hakko Omnivise PCB Holder]]
-  * [[wiki:tool:Power Supplies]]
-  * [[wiki:tool:Logic Analyzer]]
-  * [[wiki:tool:Variac]]
-  * [[wiki:tool:Function Generator]]
-  * [[wiki:tool:Rigol MSO1074Z]]
-  * [[wiki:tool:oscillator_model_k8202_400v_ac_power_supply|400V Power Supply]]
-  * [[wiki:tool:voltbox_ac_power_supply|Voltbox AC Power Supply]]
-  * [[wiki:tool:powerbright_vc-750w_step_up_down_transformer|Powerbright VC-750W Transformer]]
-  * [[wiki:tool:Terminal Crimper]]
-  * [[wiki:tool:Battery Spot Welder]]
-==== Supplies ====
-  * [[wiki:tool:Solder]]
-  * [[wiki:tool:Solder Wick]]
-  * Flux
-  * Ring Terminals
-  * Copper tip cleaner
-  * Tweezers
-  * Cleaning Brushes
-===== Kitchenette =====
-See: [[wiki:area:kitchenette|Kitchenette]]
-==== Machines ====
-  * [[wiki:tool:refrigerator|Refrigerator]]
-  * [[wiki:tool:coffee_machine|Coffee Machine]]
-  * [[wiki:tool:hot plate|Hot Plate]]
-  * [[wiki:tool:Convection Oven]]
-==== Tools ====
-  * [[wiki:tool:Brewing Equipment]]
-==== Supplies ====
-  * Cups
-===== Laser Cutter =====
-See: [[wiki:area:lasercutroom|Laser Cutting Area]]
-==== Machines ====
-  * [[wiki:tool:RedSail CM1080 Laser Cutter]]
-  * [[wiki:tool:laserfilter|Laser Cutter Filtration System]]
-==== Supplies ====
-  * [[wiki:area:material_storage|Laser Cutter Material Storage]]
-  * [[wiki:tool:laser_cutter:settings|Approved Laser Cutter Materials]]
-===== Machine Shop =====
-==== Machines ====
-  * [[wiki:tool:Green Manual Mill]]
-  * [[wiki:tool:manual_lathe|Metal Lathe]]
-  * [[wiki:tool:Bench Bandsaw]]
-  * [[wiki:tool:Horizontal Bandsaws]]
-==== Tools ====
-  * [[wiki:tool:Welder|Millermatic 211 MIG Welder]]
-  * [[wiki:tool:PowerTIG250EX|PowerTIG 250EX Welder]]
-  * Hand Tools
-  * [[wiki:tool:Norseman Drill Bit Set]]
-  * [[wiki:tool:measuring_tools|Measuring Tools]]
-==== Supplies ====
-===== Maintenance/Facility =====
-==== Machines ====
-  * [[wiki:tool:woodshop_dust_extraction_automation_system|Woodshop Dust Extraction Automation System]]
-  * [[wiki:tool:powertec_air_filter|POWERTEC AF1044 3SPD Air Filtration System]]
-  * [[wiki:tool:transformer|Power Transformer 20kVA 240V Delta to 120/208V Wye]]
-  * [[wiki:tool:Air Compressor|Campbell Hausfeld Air Compressor]] (Tank is still in use)
-  * [[wiki:tools:Boge Air Compressor|Boge Air Compressor]]
-===== Metal Shop =====
-See: [[wiki:area:welding|Metal Shop]]
-==== Machines ====
-  * Box and Pan Brake
-  * Welding Table
-  * [[wiki:tool:Bench Grinder]]
-  * [[wiki:tool:Scroll Saw]]
-  * [[wiki:tool:Buffing Machine]]
-  * [[wiki:tool:Blacksmith forge and anvil|Forge and Anvil]]
-  * [[wiki:tool:Heat Treating Oven]]
-==== Tools ====
-  * [[wiki:tool:Bosch 4.5" Angle Grinder]]
-  * [[wiki:tool:Cut-Off Saw]]
-  * [[wiki:tool:18.0V Cordless Drill]]
-  * [[wiki:tool:Plasma Cutter]]
-  * [[wiki:tool:Ring Roller]]
-  * [[wiki:tool:tube_bender]]
-  * Hand Tools
-==== Supplies ====
-  * Flux
-  * Donated metal
-===== Ops Room =====
-See: [[wiki:area:ops_room|Ops Room]]
-==== Machines ====
-  * [[wiki:tool:server_rack|Server Rack]]
-  * [[wiki:infrastructure:servers#space|Infrastructure Servers]]
-  * [[wiki:tool:fpga-cluster|FPGA Cluster]]
-===== Paint & Mess Room =====
-==== Machines ====
-  * [[wiki:tool:pressure_chamber|Pressure Chamber]]
-  * [[wiki:tool:vacuum_chamber|Vacuum Chamber]]
-  * [[wiki:tool:acrylic_bender|Acrylic Bender]]
-  * [[wiki:tool:vacuum_investment_casting_machine|Vacuum Investment Casting Machine]]
-==== Supplies ====
-  * [[wiki:tutorials:vhs_solidworks|SolidWorks]]
-  * [[wiki:tutorials:fusion360|Fusion 360]]
-===== The Hangout =====
-See: [[wiki:area:the_hangout|The Hangout]], [[wiki:area:ops_room|Ops Room]], [[wiki:area:Leopard_room|Leopard Room]], [[wiki:Area:washrooms|Washrooms]]
-==== Machines ====
-  * [[wiki:tool:Industrial Arm]]
-  * [[wiki:tool:Mini-fridge]]
-  * [[wiki:tool:Chromecast|Chromecast TV and Speakers]]
-  * [[wiki:tool:ultrasonic_cleaner|Ultrasonic Cleaner]]
-  * [[wiki:tool:Microwave]]
-  * [[wiki:tool:Video Wall]]
-  * [[wiki:tool:arcademachine|Arcade Machine]]
-==== Tools ====
-  * [[wiki:tool:labelingsupplies|Brother QL-570 Label Printer]]
-  * [[wiki:tool:admincabinet|Admin Cabinet]]
-==== Supplies ====
-  * [[wiki:tool:officesupply|Office supplies]]
-  * [[wiki:tool:Keggerator]]
-  * [[wiki:tool:labelingsupplies#box of label strips|Labeling supplies]]
-  * [[wiki:tool:cleaning_supplies|Cleaning supplies]]
-  * [[wiki:tool:social_buttons|VHS Social Buttons]]
-===== Woodworking =====
-See: [[wiki:area:Wood_shop|Wood Shop]]
-==== Machines ====
-  * [[wiki:tool:Wood CNC]]
-  * [[wiki:tool:Table Saw]]
-  * [[wiki:tool:Mini Wood (Pen) Lathe]]
-  * [[wiki:tool:Small Wood Lathe]]
-  * [[wiki:tool:Bernie the Spindle Sander]]
-  * [[wiki:tool:Bosch Miter Saw]]
-  * [[wiki:tool:hammer_jointer_planer|Hammer Jointer/Planer]]
-  * [[wiki:tool:Magnum Industrial Dust Collector]]
-==== Tools ====
-  * [[wiki:tool:Ridgid 4 Gallon Portable Vacuum]]
-  * [[wiki:tool:Thickness Sander]]
-  * [[wiki:tool:Random-Orbit Palm Sander]]
-  * [[wiki:tool:Jointer]]
-  * [[wiki:tool:Planer 40200H]]
-  * [[wiki:tool:7-1_4-inch_circular_saw|7-1/4-inch Circular Saw]]
-  * [[wiki:tool: 14" Bandsaw]]
-  * [[wiki:tool:Milwaukee Track Saw]]
-  * [[wiki:tool:Dremel Vibrating Multi Tool]]
-  * [[wiki:tool:wood steamer|Wood Steamer]]
-  * [[wiki:tool:French Cleat Wall]]
-  * Hand Tools
-==== Supplies ====
-===== Retirement =====
-[[wiki:area:Retirement|Candidates for Retirement]]
-[[wiki:area:Retired Equipment]]
