| wiki:bugs [2026/02/10 11:08] – admin | wiki:bugs [2026/02/10 11:41] (current) – removed admin | ||
| Line 1: | Line 1: | ||
| - | Some bugs in this new site | ||
| - | * ublock origins with `EasyList – Social Widgets` turned on, the youtube widget doesn' | ||
| - | * design should be a little more responsive. | ||
| - | - It falls apart on mid-sized screens - on very small screens the hamburger menu appears, but mid-size screens it's messy - ESPECIALLY when logged in because of all the extra buttons | ||
| - | * Stripe buttons are online, < | ||
| - | * redirects to add to the web server for this: | ||
| - | - `/wp/*` -> `/*` | ||
| - | * over on the membership page, there is an un-formatted link in the first FAQ question | ||
| - | # Tech stack | ||
| - | A description of the plugins and modifications done to this dokuwiki install. All the bundled plugins, plus: | ||
| - | - Advanced DokuWiki plugin - installed by tyisi to allow editing config files not otherwise available in the UI | ||
| - | - Bureaucracy Plugin - enables the [contact form](/ | ||
| - | - Commonmark Plugin - put `< | ||
| - | - folded plugin - installed but disabled, lets you make folding sections | ||
| - | - Meta plugin - used to set the page title, when we want it to be something other than the first heading on the page. used on the [Home page](/ | ||
| - | - Mikio plugin - complements our theme (mikio) by adding a bunch of bootstrap ui layout things. Used on the [membership page](/ | ||
| - | - Page Redirect plugin - used to redirect [tool](/ | ||
| - | - sectiontoggle plugin - disabled - similar to folded plugin. | ||
| - | - smtp plugin - used by the [contact](/ | ||
| - | - VHS Stripe buttons - In house plugin to add Stripe buttons for the [membership](/ | ||
| - | - VHS Tags - in-house plugin to add some custom code: `< | ||
